Car lock
KUMAR_USA
Hi folks,
Mine is Avalon XLS.
My remote car lock is not working.
I opened it and cleaned then it started working
for some time again it back to its business.
Could anybody suggest me what actually happening there.
sometimes it become so boring by opening manualy
the car doors.
Thankyou
Kumar
Nov 7, 2007 at 5:43 AM
FISHERMAN
  • 937 POSTS
[quote:24c1606823="kumar_usa"]Hi folks,
Mine is Avalon XLS.
the car doors.
Thankyou
Kumar[/quote:24c1606823]
Hello !!
did you replace the batteries?
those are lithium but eventually get weak..
what year is your car?
let us know and I can tell you the way you can program your remote once you replace the batteries in case that loss the program..
good Luck!
Nov 7, 2007 at 2:14 PM
KUMAR_USA
Hi Fisherman,
Thankyou for your reply.
the batteries are good , the brand new one.
Avalon XLS 95 model.
It is really useful if you te me the way to program that.
I appreciate your time.
Thankyou
Kumar
Nov 9, 2007 at 8:02 AM
FISHERMAN
  • 937 POSTS
[quote:fd0b3af601="kumar_usa"]Hi Fisherman,
Thankyou
Kumar[/quote:fd0b3af601]
Hello!
Here you have the instructions:
Programming for 96 Avalon remote
1. Remove key from ignition
2. Locate bulb failure warning module in the trunk (near left trunk
hinge) and disconnect electrical connector.
3. Jump pins 11 & 12 of connector with short wire or paper clip
4. Door locks will cycle
5. Press any button on remote keyless entry entry transmitter
6. Door locks will cycle
7. Repeat steps 5 & 6 for another transmitter
8. Remove jumper from connector and reconnect to module
NOTE: A max of 2 transmitters can be programmed to a car
Good Luck!
We appreciate your donation (if possible)
Have a Nice day!
Nov 9, 2007 at 8:37 AM
KUMAR_USA
Hi Fisherman,
Thankyou for your help..
I will try it out..
bye
Kumar
Nov 13, 2007 at 9:28 AM
FISHERMAN
  • 937 POSTS
[quote:1246bfbf61="kumar_usa"]Hi Fisherman,
I will try it out..
bye
Kumar[/quote:1246bfbf61]
Hey Kumar !
Let us Know if works !
Good Luck!
Nov 13, 2007 at 10:08 AM
