99 avalon xls, dies after started.
HTENG2007
99 avalon xls 6 cycliner, auto
Sometimes the engine is kind of shaking after started, and then as soon as I put the shift into reverse it dies.
But as long as the car is running, everything seems fine. It feels normal at high speed, low speed, even at the stop signs.
What can be the cause of this?
Thanks
EDIT: If I give it a little gas, the idle shaking usually gets better. But since I have to lift my foot from gas to brake in order to put the shift into reverse, this does not help.
'Shaking' probably is not the right word for it. When that happens it feels as if the engine is running too slow to maintain its rhythm, like missing beats.
There are/were no lights on.
Nov 6, 2007 at 9:41 AM
FISHERMAN
  • 937 POSTS
[quote:e93c7022bb="hteng2007"]99 avalon xls 6 cycliner, auto
Thanks
There are/were no lights on.[/quote:e93c7022bb]
Hello!
Start checking the IAC valve (Idle air control valve)
remove it and clean all gummed area and varnish..
Usually that valve its responsible to control the idle and increase it under "load"
let us know how is it!
Good Luck!
Nov 6, 2007 at 11:14 AM
FISHERMAN
  • 937 POSTS
IAC Valve Location and test:
https://images.2carpros.com/forum/automotive_pictures/576_avalon_99_iac_1.jpg
Nov 6, 2007 at 11:24 AM
HTENG2007
Thank you fisherman.
I started with IAC valve. But it soon became too much for me I sent it to my friend mechanic for a tune-up(One is due anyways). According to him, it was a dirty dirty throttle.
Problem fixed after $400.
Nov 10, 2007 at 1:36 AM
