2006 Toyota Avalon meantince requred
66,000 MILES • 6 CYL • FWD • AUTOMATIC
ALI2176
my car has warning light it said meantince requred,i cheked th car manul,and its said i have to change oil,and i did but the problem still the same,light still on,how can i make this worning light go off?thank you feed me back please.
Oct 8, 2010 at 4:03 AM
DSPLC
  • 220 POSTS
Turn the key ON,but don't start it. Make sure the odometer is showing the actual mileage,not trip A or B.Turn the key back to the OFF position,then press and HOLD the trip/reset button.Continue to hold it down and turn the key to the ON position.(Do not start, just ON position). Continue holding the trip/reset button while the mileage shows all zeros until the actual mileage appears again usually takes around 5 seconds. Release the button and see if the maintenance light disappears.
Oct 10, 2010 at 5:13 PM
