2004 Toyota Avalon Fuel Gauge
32,000 MILES • 6 CYL • FWD • AUTOMATIC
JUANAWINFIELD
My fuel gauge reading on the instrument cluster that tells you how many miles you have left to drive once you fill up the gas tank does not work properly.
When I fill up the tank, the gauge usually reads 250 miles. Later on, the tank reading will increase to about 370 miles. Is there anything that I can do to get the car to recognize the complete fuel capacity when I initially fill the tank? Thanx
Nov 7, 2008 at 8:52 AM
S_AUR_SS
Dear Juan,
Is your problem solved now.I also has the same problem.if i am driving on town only max tank capacity it will read 339kms.& if i will drive on highways after some times it start reading 459 kms.If ur problem was solved than do send me mail on s_aur_ss@yahoo.com i will be thankfull to you.
Best Regards,
Sandy
Nov 1, 2009 at 11:32 AM
