2002 Toyota Avalon temptpeture gauge is raises to high temp
102,000 MILES • 6 CYL • FWD • AUTOMATIC
ALTHEDON
what should i look for to try to correct this problem?
May 8, 2010 at 4:40 AM
  • 31,937 POSTS
Hi there,
If the engine temp is normal and the gauge is reading high, replace the sender as it may be faulty.
mark (mhpautos)
May 8, 2010 at 8:45 PM
JSOHN
check the thermostat and do a pressure test to check for a coolant leak.
May 28, 2010 at 12:34 PM
