Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Avalon
Interior
Instrument Cluster
Gauges
Engine Temperature
2002 Toyota Avalon temptpeture gauge is raises to high temp
2002 TOYOTA AVALON
102,000 MILES • 6 CYL • FWD • AUTOMATIC
ALTHEDON
MEMBER
1 POST
what should i look for to try to correct this problem?
May 8, 2010 at 4:40 AM
Experienced Mechanic
Hi there,
If the engine temp is normal and the gauge is reading high, replace the sender as it may be faulty.
mark (mhpautos)
May 8, 2010 at 8:45 PM
JSOHN
MEMBER
check the thermostat and do a pressure test to check for a coolant leak.
May 28, 2010 at 12:34 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
