2002 Toyota Avalon Head Gasket
2002 TOYOTA AVALON
LAZTURN
Engine Mechanical problem
2002 Toyota Avalon 6 cyl Two Wheel Drive Automatic 200K miles
Hi there,
I think I have a blown head gasket. I put an oil flush through and changed the oil. The old sump oil had a smell of fuel to it. Also, some of the bright red flush liquid ended up in the coolant reservoir. And finally, when idling with the radiator cap off, little bubbles are coming up the radiator.
Being on a pension I am trying to do this as cheap as possible, so my question is:
What is the easiest way to identify which cylinder, it is so I know which head to remove for gasket change?
I realise that this could also mean the head may be warped or cracked.
Where are the spark plugs on the avalon (I am assuming it's the black boxes on the head) and is there anything special that is needed to be done before removing them.
and lastly what is the head bolt loosening order for the avalon engine?
Thankyou in advance.
Andrew
Aug 8, 2009 at 3:42 PM
STEVEW84
  • 673 POSTS
Well, first off. Is the car overheating?
Aug 11, 2009 at 12:10 AM
LAZTURN
No, the car has never overheated and the fluid have always been checked and maintained. I do this monthly.
I have been told that it's a fault of this engine type, the alloy heads expand and contract with the heat at different rates and this happens - but I don't know how feasible this is, I can't find anything about that.
Aug 11, 2009 at 12:14 AM
STEVEW84
  • 673 POSTS
well, I would say if it is not overheating or running like crap then I would say you don't have a headgasket problem. Are you having any problems with it?
Aug 11, 2009 at 12:52 AM
