2002 Toyota Avalon Brake shims
2002 TOYOTA AVALON
82,000 MILES • 6 CYL • FWD • AUTOMATIC
BAMLIN
replacing oem pads with akebono ceramic due to dusting problems. OEM pads have an inner and outer shim on each pad, the Akebono has what they call a noise insulator attached permanently to the pad. Do I still use the Shims I remove from the OEM pads on the replacement pads or just use the attached noise insulator without installing the shims?
Apr 20, 2008 at 8:28 AM
  • 31,937 POSTS
I would re fit the shims.
Mark (mhpautos)
Apr 20, 2008 at 5:29 PM
