Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Avalon
Safety
Traction Control
The VSC and VSC OFF lights on the dash stay on
2001 TOYOTA AVALON
58,000 MILES • 6 CYL • FWD • AUTOMATIC
MRWOJO
MEMBER
1 POST
The VSC and VSC OFF lights on the dash stay on in addition the codes say I need left rear wheel speed sensor
Aug 6, 2008 at 1:51 PM
Experienced Mechanic
This is normally a wheel speed sensor or a module issue. However, the fact that you have a speed sensor code makes that the issue.
Here are some guides that will help with this:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Below is the process from the manual that will help with replacing the rear sensor. Please let us know if you have other questions. Thanks
Images (Click to enlarge)
May 9, 2021 at 1:22 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
