2001 Toyota Avalon Post-Jump Problem
FRISKYPANDA
2001 Toyota Avalon 6 cyl Automatic 115000 miles
Interior map light left on & drained battery. Gave it a jump & charge seemed to take; however, when tried to accelerate, car would not respond. Rather, it would sputter & rpm gauge actually went down when depressing accelerator. Initially, could not go more than @ 15 mph. Used soda & water to remove some crud from positive terminal (per response in a dead battery forum), let car sit for few hours then started it again. Let it run with all accessories OFF then tried to drive again. Though was able to increase speed to @ 30 mph, it reacted similarly - it seemed to have trouble switching gears. Also noticed a burn smell after leaving car. Can someone PLEASE advise.
Jun 13, 2010 at 1:29 PM
  • 31,937 POSTS
Hi there,
Did you do a scan as yet to see if this problem has registered a fault code, (not all faults will trigger a check light)
mark (mhpautos)
Jun 13, 2010 at 11:13 PM
