2001 Toyota Avalon p0440 p0442
98,656 MILES • 6 CYL • 2WD • AUTOMATIC
CML5456
  • 8 POSTS
have a 2001 toyota avalon, recently 2 codes pop on, p0440 and p0442, tried to erase 1 time, but comes back on again in a couple days. p0440(EVAP Emission Control Syatem Malfunction) appear as code of 1 and 2 for the total of 3 codes found. which means it appeared repeated as i scroll down the 3 codes. the last code is p0442(EVAP Emission Control System Lead, SMALL). can anyone machanic help me to pin point this problem? thank you very much!!!
Dec 30, 2008 at 7:47 AM
IMPALASS
  • 3,112 POSTS
Hello - I have attached the troubleshooting chart for this. As you see the big thing is the fuel cap either improperly installed or cracked or leaking in some way. My suggestion is look at all the hoses etc really well for cracks, damage, chaffing, good tight connections. Then purchase a new fuel cap Clear the codes and see how it does. If it comes back the we do some more troubleshooting.
https://images.2carpros.com/forum/automotive_pictures/248015_2_88.jpg
https://images.2carpros.com/forum/automotive_pictures/248015_1_136.jpg
Dec 30, 2008 at 3:04 PM
IMPALASS
  • 3,112 POSTS
Hello –
Hey one more thing……. Looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
SSC10E
04/01/2001
Recall - Front Subframe Replacement
NHTSA01V072000
03/02/2001
Recall 01V072000: Front Sub-Frame Assembly Defect
Dec 30, 2008 at 3:05 PM
