Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Avalon
Engine
Oxygen Sensor
Replace/Remove
2001 Toyota Avalon o2 sensor
2001 TOYOTA AVALON
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRUCKERDAVE
MEMBER
1 POST
why wont the check engine light go out after i changed the oxygen sensor
Mar 28, 2009 at 10:34 AM
BLUELIGHTNIN6
Experienced Mechanic
Need to have the code deleted. Either use diagnostic scanner to delete code or disconnect ground battery cable for 10 minutes then reconnect.
Thanks for using 2CarPros.com!
Mar 29, 2009 at 5:32 PM
WILLIAM OLIVER
MEMBER
disconect the efi fuse for 20 sec. wich is in the engine room side to the battery 15amp fuse ( blue color )
Mar 30, 2009 at 4:28 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
