2001 Toyota Avalon o2 sensor
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
TRUCKERDAVE
why wont the check engine light go out after i changed the oxygen sensor
Mar 28, 2009 at 10:34 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to have the code deleted. Either use diagnostic scanner to delete code or disconnect ground battery cable for 10 minutes then reconnect.
Thanks for using 2CarPros.com!
Mar 29, 2009 at 5:32 PM
WILLIAM OLIVER
  • 25 POSTS
disconect the efi fuse for 20 sec. wich is in the engine room side to the battery 15amp fuse ( blue color )
Mar 30, 2009 at 4:28 PM
