2001 Toyota Avalon idle speed control valve
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
TOY AVALON
Attempting to find info on the idle speed control valve, as I am having intermitant problems with low idle speeds on startup after car is hot.
Jun 3, 2008 at 8:37 AM
  • 75,988 POSTS
A problem with the idle air control valve will give you an OBD2 P0505. Find it and clean it out and also check the coolant temperature and throttle position sensors.
Jun 3, 2008 at 8:47 AM
