neutral safety switch?
MILOHASTE
so if the car will start but not come out of gear is it most likely the safety neutral switch?
Oct 22, 2009 at 1:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
that is one possibility, yes. other possibilities include internal damage to the transaxle. did you have any changes in performance of the transaxle prior to this? if not then the switch is most likely culprit.
Oct 22, 2009 at 1:44 PM
HSPARKSJR1980
The 1999 Avalon sometimes starts, and other times does not. Sometimes you need to wiggle the steering wheel, sometimes the shifter, and sometimes it works or not. The battery is 100% fully charged.
Nov 25, 2023 at 2:53 AM
  • 55,647 POSTS
I have seen a bad starter cause this problem but to be sure this is the issue we can use a test light to monitor the starter trigger wire when in the crank position, if the test light shows a signal the starter is bad.
Here is a guide to help us fix the problem:
Here is the starter location so we can confirm the issue. When you move things around it can cause the starter armature to move slightly and cause the starter to work once again. Check out the images (below). Please upload pictures or videos of the problem so we can see what's going on.
Nov 26, 2023 at 3:17 AM
