1998 Toyota Avalon water not draining from door
TUCKERSHREWSBURY
Interior problem
1998 Toyota Avalon 6 cyl Front Wheel Drive Automatic
Rain water is not draining from doors on passanger side of my Avalon. After every rain storm I have to open the doors and hold the rubber strip away from drain holes in order for a consderable amout of water to drain. The water has now started to drain from the interior door panel also. This water drainage problem has been occurring for a few months now. I should mention about 4 years ago the passenger side of the car was repaired after an accident. I'm concerned the interior door panels will rust out. Is this something I can try to repair myself? If so, please tell me how I would do this. Thank you very much.
Jun 6, 2008 at 3:33 PM
KHLOW2008
  • 41,812 POSTS
Hi tuckershrewsbury,
Ensure drain holes are not clogged, there should be (2 or 3).
If the weatherstrip is blocking them, it is not properly seated.
If water is draining from the panels, the plastic shield behind it is not properly sealed or torn.
Jun 7, 2008 at 2:53 AM
MIKEBEAR
The problem is NOT a problem caused by your repair. Rather the drain holes on the very bottom of door are clogged, preventing water from draining after rain or car washing. Despite some Toyota techs objections, this problem IS a chronic design problem because the drain holes in the trim do not align with the drain holes in the sheet metal of the door. Thus they set the stage a clogged drain. It tends to be the rear doors on either side that have the problem most often. One fix I read said to drill a 1/8 hole in the extreme bottom of every door to fix this permanently. This fix will work, but since Toyota forgot to coordinate those hole positions between the two parts. I prefer to remove the trim and drill it where the original drain holes in the sheet metal are located. Hope this helps. If you cannot do it, print this answer take it to any reputable body shop, who can do it in a snap.
Aug 2, 2008 at 3:09 PM
