I am getting codes for cylinder 2, 5 and random cylinder misfires. I changed all spark plugs, replaced the PCV valve just for good measure, and changed the wire set. First, I want to make sure that I replaced the wires in the correct order. It is my understanding that the back cylinders are 1, 3,5 from left to right if viewed from the front of the vehicle and the front cylinders are 2,4,6 again, from left to right. I saw an old posting for a 96 that said the wire pairing should be 1&4, 2&5, and 3&6. If this pairing is correct for the 98 as well? Also, if the problem is unchanged, would the next logical step be to change the ignition coil for those cylinders?
Oct 23, 2009 at 11:42 AM
