Random cylinder misfire
230,000 MILES • 6 CYL • 2WD • AUTOMATIC
NATALIANEAL84
I am getting codes for cylinder 2, 5 and random cylinder misfires. I changed all spark plugs, replaced the PCV valve just for good measure, and changed the wire set. First, I want to make sure that I replaced the wires in the correct order. It is my understanding that the back cylinders are 1, 3,5 from left to right if viewed from the front of the vehicle and the front cylinders are 2,4,6 again, from left to right. I saw an old posting for a 96 that said the wire pairing should be 1&4, 2&5, and 3&6. If this pairing is correct for the 98 as well? Also, if the problem is unchanged, would the next logical step be to change the ignition coil for those cylinders?
Oct 23, 2009 at 11:42 AM
MATHIASO
  • 1,209 POSTS
you right for the firing order . 1-2-3-4-5-6-Distributorless 1MZ-FE engines I'm sending the firing order in your email, so you can see it bigger than this.
https://images.2carpros.com/forum/automotive_pictures/46384_firing_order_1.jpg
if the wire have been replaced in the correct order and it is the random misfire you got before you changed the spark plugs and wires the the ignition coil could be suspected.
Oct 24, 2009 at 8:56 AM
DJI'AUTO SERVICE
Oui, c'est exact, j'ai eu le même problème.
Translation: Yes, that's correct, I had the same problem.
Jul 4, 2020 at 9:54 AM
From what I can get translated, it looks like you are confirm what was stated earlier. If so, thanks for jumping in and adding to the post.
If there is anything we can help you will, just let us know. Thanks
Jul 4, 2020 at 10:55 AM
