1998 Toyota Avalon oil light
1998 TOYOTA AVALON
237,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALONGAMORE17
My cars oil light has come on. I had the oil pressure checked and it was fine then i had the oil changed.... then it went off. Then the other day us came on again and i has the sending unit replaced but the light is on and staying on. There is no ticking noices and i cant seem to find anyone who knows whats wrong. Could it be electrical?
Feb 18, 2009 at 6:00 AM
IMPALASS
  • 3,112 POSTS
Hello
To better assist you please let me know if your model is a XL or XLS. Also your engine size in liter.
Feb 18, 2009 at 6:09 AM
Light staying on constantly means low oil pressure
Possible causes include:
Excessive main and rod bearing clearances (someone may have installed the wrong-sized bearings or standard-sized bearings on a reground crankshaft). Only 0.001" of extra clearance in the main bearings can reduce oil pressure by up to 20%!
Excessive camshaft bearing clearances (a bearing may have slipped out of place when the cam was installed).
Excessive clearances inside the oil pump.
Leaks between the oil pump and engine.
Oil pump relief valve stuck open or installed backward.
A loose or mispositioned oil pickup tube (too high in the oil pan).
A defective oil pressure sending unit or oil pressure gauge.
Low oil level in the oil pan.
Cracks or leaks in the oil galleries or gallery plugs.
Cracked oil pump housing (improper installation).
Oil viscosity too thin for hot weather.
Oil viscosity too thick for cold weather.
Feb 18, 2009 at 6:14 AM
ALONGAMORE17
Its an xls and a v6
