1998 Toyota Avalon gear select
1998 TOYOTA AVALON
62,000 MILES • 4 CYL • FWD • AUTOMATIC
MADATCAR
Will not allow gear selector to be moved from park with brake depressed
Jan 21, 2008 at 7:33 PM
BMRFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 19,053 POSTS
[quote:5ff9f57408="madatcar"]Transmission problem
1998 Toyota Avalon 4 cyl Front Wheel Drive Automatic 62000 miles
Will not allow gear selector to be moved from park with brake depressed[/quote:5ff9f57408]
u should have an over ride beside the shifter \
check if you have brake light
check brake light switch and check actuator
Jan 21, 2008 at 8:09 PM
