1997 Toyota Avalon Instrument Panel
168,000 MILES • 6 CYL • FWD • AUTOMATIC
BRANDY LA SALLE
I recently noticed that the lights for my speedomiter, gas gauge and RMP dose not turn on when I turn on my headlights any more. I have checked most of the fuses but am unsure which one it is as the manuel does not tell me which fuse to check. If that is not the problem what else could it be. No recent front end damage just an all of the sudden problem that makes it diffecult to drive at night.
Sep 23, 2010 at 6:37 AM
DSPLC
  • 220 POSTS
Beside your power side mirror switch or above your hood release lever, there is a knob with a picture of a light bulb. Rotate clockwise to brighten instrument panel light and counterclockwise to to dim or turn off light.
If there is a coin box above the hood release lever, pull it and there should be fuses located behind it...On the back of the coin box is a diagram of what the fuses are for. Locate the 7.5 A PANEL fuse. This controls the instrument panel light.
Sep 23, 2010 at 11:31 AM
