1996 Toyota Avalon very high idle when warm
1996 TOYOTA AVALON
81,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEN7357
My Avalon idles about 2000rpm for about 30 seconds to 1 minute even when the outside air temp is 70 degrees or above. After only about 2 minutes will the idle drop to below 1000rpm and finally settling at about 750rpm when at operating temp.
I have already changed the coolant temp sensor and have had a mech analyze the system as a whole.
Any suggestions? or is this idle speed normal?
Sep 2, 2008 at 9:56 PM
YAMI
I had the same thing happen. My first recourse was to to adjust the idle, but only got as far as pulling on the throttle cable under the hood. I then looked in the manual...nothing! Then I came here...so I guess, we just have to let the car idle for more then 2 minutes before we drive away...I noticed the high RPMS too! Its tough on brakes when u back-up...disc brakes squeal. greenphotos@hotmail.com
Nov 9, 2008 at 9:29 PM
