1996 Toyota Avalon trouble codes
153,000 MILES • 6 CYL • FWD • AUTOMATIC
GRIF2COOL
I been getting the PO300, 301, and 303 codes and wanted to try and fix the problem this weekend,
what would you suggest I check first??
Mar 19, 2009 at 5:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
These codes all indicate a misfire on cylinders 1 and 3. I suggest checking your spark plugs and fuel injectors for proper operation. I would suspect a faulty coil pack since it is 1 and 3 cylinders. Post results of the spark and fuel injector inspection and I will follow up.
Thanks for using 2CarPros.com!
Mar 19, 2009 at 6:58 AM
WILLIAM OLIVER
  • 25 POSTS
also ck compression more then 185 psi min to be ok
Mar 28, 2009 at 3:04 PM
