Even after pushing the reset button will not disengage from park
May 3, 2009 at 11:46 AM
2CARPRO JACK
✓Experienced Mechanic
First check these fuses,
cig&rad - 15 amp
ecu-ign - 15 amp
stop lamp- 15 amp
see if brake lights work if fuses are all good, if not the brake light switch is probably bad, test for power in to brake switch (/white/red wire) then power out when brake applied (green/white wire)
