1996 Toyota Avalon shifter
1996 TOYOTA AVALON
20,000 MILES • 6 CYL • FWD • AUTOMATIC
PDKILLGORE
Even after pushing the reset button will not disengage from park
May 3, 2009 at 11:46 AM
2CARPRO JACK
  • 11,533 POSTS
First check these fuses,
cig&rad - 15 amp
ecu-ign - 15 amp
stop lamp- 15 amp
see if brake lights work if fuses are all good, if not the brake light switch is probably bad, test for power in to brake switch (/white/red wire) then power out when brake applied (green/white wire)
May 4, 2009 at 12:58 AM
