1996 Toyota Avalon Engine cover
145,000 MILES • 6 CYL • FWD • AUTOMATIC
M.TAKAKI
I am trying to replace the spark plugs on my V 6 lThe engine cover has two fastners on top. I tried a #5 metric allen wrench on it but it does not seem to fit right. Any suggestions?
May 18, 2008 at 12:55 AM
LEGITIMATE007
  • 5,121 POSTS
I think you need a torx bit (star bit) on that cover
May 18, 2008 at 1:20 AM
PCMENTOR29
  • 177 POSTS
What I used for the top plastic cover bolts was to hammer a flat screwdrver bit that just fit and then was able to remove the cover. Also I didn't try a metric hex bit which may have also worked. I now just leave them loose. They can't rattle out the way they are attached.
Dec 8, 2012 at 11:19 PM
