1996 Toyota Avalon engine
160,000 MILES • 6 CYL • FWD • MANUAL
JIM KELSO
engine leaks a small amount of oil around the head and recently had struts, the rear struts thump when I hit a small bump in the road. James Kelso
Mar 4, 2008 at 3:55 AM
MASTERTECHTIM
  • 4,750 POSTS
when you had the struts replaced did you also have the sway bar end links and bushings replaced? i find most times that sway bar end links and or bushings are what is causing the thump over bumps and that in fact the struts are not. also is the oil leaking from the head or the valve cover?
Mar 4, 2008 at 4:12 AM
JIM KELSO
[quote:ca5af835d4="mastertechtim"]when you had the struts replaced did you also have the sway bar end links and bushings replaced? i find most times that sway bar end links and or bushings are what is causing the thump over bumps and that in fact the struts are not. also is the oil leaking from the head or the valve cover?[/quote:ca5af835d4] :lol: The leak is from the valve cover I believe thank you Jim
Mar 4, 2008 at 4:29 AM
