obd connector location
190,500 MILES • 6 CYL • 2WD • AUTOMATIC
JM8540
Hello 2CarPros -
Where is the OBD 2 socket in my 1995 Toyota Avalon XL 4-door sedan? My mechanic said iit should be just behind the brake pedal, but I don't see it.
Thanks for your help,
John
Jul 23, 2009 at 2:50 AM
STEVEW84
  • 673 POSTS
actually it is more by the hood latch and it is not a normall OBD 2 connector. Actually it might have an ob2 connector and it might have an obd1 connector.
Jul 23, 2009 at 2:30 PM
JM8540
Hello stevew84 -
Thanks for your reply. I'm pretty sure that this car is fully OBD II compliant, based on internet searches which show a list of compliant models.
What do you mean when you say "... not a normal OBD 2 connector ..." ? I'll look for the plug in that area and see what I find.
Thanks again.
Jul 24, 2009 at 1:56 AM
STEVEW84
  • 673 POSTS
I'm sure you have an obd2 connector, but because its a 95 I'm also sure it has an obd1 connector. ob1
https://images.2carpros.com/forum/automotive_pictures/170495_toyota_1_1.jpg
obd2
https://images.2carpros.com/forum/automotive_pictures/170495_toyota_2_1.gif
Jul 24, 2009 at 3:57 AM
JM8540
Hello again, stevvew84 -
Yes, lower left by the hood latch, just as you said. Okay, now what do I do? Shouldn't I get an OBD II code reader? The 'check engine' light iis sporadic, it comes on for a day or two, then is off for a week. Engine temperature and fluid levels are fine, I just want to know what iis causing the CE light.
Thanks again for your help and accurate info,
John
Jul 26, 2009 at 4:39 AM
STEVEW84
  • 673 POSTS
if there is an obd 2 connector then I would hook into that first. if the check engine light is on and off then there should still be a code. If you can't get communication from the obd2 connector then you have to get a scanner that has obd1 connectors. That would be a lot more expensive than a $35 code reader. HTH.
Jul 26, 2009 at 5:34 AM
JM8540
stevew84 - thanks for your help and your time - this is my first time using 2CarPros, what do I do now? Do I close this thread? Please advise, and thanks.
Regards,
John
Jul 27, 2009 at 4:03 AM
STEVEW84
  • 673 POSTS
Actually, I don't know. I think your fine doing nothing.
Jul 27, 2009 at 5:16 AM
