1995 Toyota Avalon 95 Toyota Avalon ignition coils
1995 TOYOTA AVALON
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
CAVALIER.26
MEMBER
1 POST
I have a Toyota Avalon that doesn't have power on the ignition coils. I replaced the coils and still have not power. Somebody know the reasons?.
Sep 18, 2010 at 10:15 AM
ERNEST CLARK
✓Experienced Mechanic
The first thing to check is the fuse/relays for your ignition switch. Then check the wiring harness from the coil pack to the computer. (including the contacts)
Your computer needs to see a signal from the Cam and crankshaft sensors before it'll pass a signal to the coils to fire.
Check both of these sensors as well as the wiring/connectors.
If all is good, then you're probably looking at a bad computer.
Sep 21, 2010 at 2:46 AM
