Toyota 4Runner timing mark
IFTIHASAN
Engine Mechanical problem
Toyota 4Runner 6 cyl Four Wheel Drive Automatic 92000 miles
Ihave toyota 4 runner sr5 3.0 1992 suv, i changed the timing belt the problem now i heve to set the timing mark which is on cam and crank shaft can u show correct alingment marks by photo whereit shoud go under the info is 10 BTDC.
Mar 4, 2010 at 4:41 AM
2CARPRO JACK
  • 11,533 POSTS
If you are refering to the cam/crank alignment marks for timing belt replacement, here you go, if not let me know what it is you need...thx
https://images.2carpros.com/forum/automotive_pictures/1639_yota_3.jpg
Mar 4, 2010 at 12:24 PM
