1989 Toyota 4Runner Dies After MAF Swap
MHALL
I have an 89 4Runner SR5, 4cyl with 150,000 miles. It had been sitting for about 2 years, so I flushed the gas tank, replaced the plugs , the wires, the distributor, and the water pump. The engine was idling sporadically high and low at irregular intervals, so I replaced the MAF sensor. Now the engine dies almost right away, and it won't accelerate. Any ideas?
Apr 26, 2006 at 12:07 AM
LOSONE
  • 1,616 POSTS
CHange the fuel filter and check the fule pressure. It could be the pressure regulator. Good luck.
May 1, 2006 at 4:59 AM
MHALL
It turned out to be the the MAF sensor that I replaced. I put the old one back in and now it's back to the original problem. I found in the Chilton's manual how to run a diagnostics, and the problem is with the throttle position sensor. The new one comes in tomorrow. I hope it works.
May 1, 2006 at 10:52 AM
Suggested Repair
Replace the fuel filter and check fuel pressure, including the pressure regulator. The replacement MAF was faulty, so reinstall a known-good MAF; a manual diagnostic test also pointed to the throttle position sensor, which was not yet confirmed as the fix.
Conversation Summary
A 1989 Toyota 4Runner that had sat for about two years idled irregularly, then stalled immediately and would not accelerate after the MAF was replaced. The expert advised changing the fuel filter and checking fuel pressure, possibly the pressure regulator. The owner found the new MAF was bad, restored the original idle problem by reinstalling the old MAF, and a Chilton diagnostic test indicated the throttle position sensor.
