Toyota EGR Check Engine Light
LOUIEMCGOON
My Toyota Prerunner, 4 door, 94,000 miles, 4 cylinder had the check light come on 6 months ago and the code said that I needed to change my EGR valve. So I changed that valve but just over a month the light keep coming on than off a day or two later and it was still saying the code for the EGR valve. What could be the problem?
May 10, 2007 at 9:56 AM
  • 75,988 POSTS
[quote:f7be0e5e0d="louiemcgoon"]My Toyota Prerunner, 4 door, 94,000 miles, 4 cylinder had the check light come on 6 months ago and the code said that I needed to change my EGR valve. So I changed that valve but just over a month the light keep coming on than off a day or two later and it was still saying the code for the EGR valve. What could be the problem?[/quote:f7be0e5e0d]
Did you change the vacuum switching solenoid this is the one that provides vacuum to the EGR
May 10, 2007 at 9:59 AM
Suggested Repair
Check the EGR vacuum switching solenoid, which supplies vacuum to the EGR valve, since the EGR code returned after the valve was replaced.
Conversation Summary
The owner of a Toyota reported a check engine light and an EGR valve code. The EGR valve was replaced, but the light continued to come on intermittently and the same code remained. The expert asked whether the vacuum switching solenoid that provides vacuum to the EGR had also been replaced.
