Car jerks
GAJOHNSON
Toyota 4Runner 1999 125K - Just noticed truck started jerking, usually just a quick one, once I would hit 2 to 3 rpms & do it again till I got past say 30/35mph, once at that speed, no more 'jerks/surges'. I had the Catalytic converter's changed around 110K, not certain if this is the issue again or if it's transmission-related. Thanku
Oct 19, 2007 at 1:07 AM
2CARPRO JACK
  • 11,533 POSTS
Could be an intermittent miss.... have you ever tuned it up? If you did, what parts were used? Cheaper parts are exactly that.....
Oct 19, 2007 at 4:20 AM
GAJOHNSON
Actually on way home Fri, check engine lite came on, temp shot past "H" & car shut down -- overheated I suppose, had towed, was told this AM, I had a hole in the radiator that caused the coolant to mix w/the transmission, all the fluids were 'mixed'. They're replacing the Radiator, said this is a definite to get the car runnign again, replacing trans filter & doing a coolant flush & transmission flush & seeing IF this was the problem & corrects it, this is 'Best case scenario' I was told - worse case is all the 'fluids' could have gotten into the transmission/engine, (think he mentioned a head gasket?!) & I could need a whole new transmission/engine - What are the chances I'm facing a 'worst case' scenario & having to replace a trans/engine?!
Oct 22, 2007 at 2:54 AM
