Car battery?!
BIG_BILL61
Ok i have a 1987 toyota 4runner 4 wheel drive, and i just replaced the tranny the clutch and throghout bearing...and it wont start now. i put the key in i got radio lights all the electrical stuff... what could it be? it will run if its jumped...
Sep 14, 2007 at 6:07 AM
  • 75,988 POSTS
[quote:fe0d582f43="Big_Bill61"]Ok i have a 1987 toyota 4runner 4 wheel drive, and i just replaced the tranny the clutch and throghout bearing...and it wont start now. i put the key in i got radio lights all the electrical stuff... what could it be? it will run if its jumped...[/quote:fe0d582f43]
Welcome to 2carpros
Go back down to the starter and double check all your connections to include the battery. Now start checking these components-starter relay/clutch/and ignition switch.
Try this the clutch switch is located on the clutch pedal bracket jump the connector and see what happens.
Sep 14, 2007 at 8:46 AM
