1998 Toyota 4Runner Left Turn Clunk
WANNABE
1998 Toyota 4 Runner SR5 Auto, 4WD, 131,000 miles. Has been maintained per manufacturers schedule. Only problem thus far has been the replacement of the oil sensor sending unit (vehicle was leaking oil). No "4 wheeling". Only normail driving. Has been driven primarily in the city.
My problem: When I am turning LEFT at slow speeds (as at an intersection), I hear a loud clunking sound coming from under the car. I can feel it. It sounds like someone is under the vehicle with a hammer. It does not occur when I turn right, only left. At normal low and high speeds straight ahead, there is no problem. Vehicle runs good otherwise. Sometimes the clunking is very loud and sometimes not so loud.Thanks for any help. PS I made a "small donation".
Jul 8, 2007 at 1:08 PM
2CARPRO JACK
  • 11,533 POSTS
Start basic and check the wheel bearings and suspension parts for wear and for anything that could possibly hit the wheel on a turn. Might even just be the steering stop hitting the control arm
Jul 9, 2007 at 1:06 AM
Suggested Repair
Inspect the wheel bearings and suspension parts for wear and for anything that could contact the wheel during a left turn. Also check whether the steering stop is hitting the control arm.
Conversation Summary
The owner of a 1998 Toyota 4Runner reports a loud clunk felt under the vehicle only when turning left at slow speeds. Straight driving and right turns are normal. The expert advises checking wheel bearings and suspension parts for wear or contact, including a possible steering stop hitting the control arm.
