4x4 troubles
BLOUIE
I have a 2001 toyota 4runner 4x4 w/58,000 miles. As I approached the highway and was driving at 55 mph I disengaged the 4wheel (4H) drive button then the vehicle slowed down and stopped. I was able to shift it into 4L and drive slowly home. It will not shift out of 4wheel drive. Please help?
Feb 18, 2007 at 5:45 AM
W2MGARDENHOSE304
You should never disengage the 4x4 while moving, always put it in park, and then do it. I did that with a 4x4 ranger on time and screwed up the lock differential. The problem I had when I did that was that I was unable to put it back into 2wd. I got it fixed for about 600 bucks and it worked fine after that.
Feb 21, 2007 at 12:13 PM
