I have a 1995 4Runner with 107,000 miles. It is a 6 cylinder 4WD.
The previous owner had the head gaskets repaired. Two years later I had the engine rebuilt.
About a year later it started to overheat and the dealership replaced my radiator ... said it was rusting and clogged.
About 3 months later it started to overheat again. They cleaned the radiator but said it wasn't really clogged. They figured there was a problem with the head gaskets again.
After that the car did not overheat for several months. It is now overheating again.
I'm assuming it's the head gaskets, but could it be anything else? Can you explain why it would run fine after that recent radiator cleaning?
Oct 21, 2007 at 12:46 PM
