2005 Toyota 4Runner
54,000 MILES • V8 • 2WD • AUTOMATIC
C_S_CHENG
Just bought a used 2005 4runner. Windshield wipers do not dispense fluid. No motor sound. Hoses not blocked. Fuse is good. Not leaking from reservoir. Pump is good. Loose wiring?
Dec 17, 2008 at 1:36 PM
  • 31,937 POSTS
Hi there check for power at the washer motor plug with a test light if there is power when you press the button the pump will be faulty, check this first.
Mark (mhpautos)
Dec 17, 2008 at 1:39 PM
