2003 Toyota 4Runner wrong fuel
HARRYTHEHILUX
Other Category problem
2003 Toyota 4Runner 4 cyl Four Wheel Drive Manual 85.000 miles
i put unleaded instead of diesel what should i do to get it running properly
i drove it 4 5km than stop and got it towed and haven;t driven since what needs to happen to fix this now
Dec 8, 2007 at 6:25 PM
  • 31,937 POSTS
Hi there,
Drain the fuel tank and flush out with diesel, blow out fuel lines and change filter. remove injector fuel return line (where it comes of the rail under the in let manifold and prim the pump and return rail with fuel, use hand pump on filter to flush out , crack open injector lines at injectors and crank over to flush out lines.
You can only hope that there is no damage to the pump and injectors as petrol is not a lubricant (the diesel acts as a lubricant as well) so some over heating and binding may have resulted, time will tell.
Mark (mhpautos)
Dec 8, 2007 at 7:09 PM
