2003 Toyota 4Runner Sunroof
23,000 MILES • V8 • 4WD • AUTOMATIC
PAUL.HANKINS
  • 6 POSTS
When opening the sunroof on the '03 4runner, i heard 3 loud clicks on the driver side as it reached the fully open position. When I tried closing it, the motor engaged, the passenger side looks like it is trying to close but the driver side doesnt budge and the motor shuts off.
Any idea what could be wrong?
Sep 8, 2008 at 11:28 AM
SERVICE WRITER
  • 9,123 POSTS
Sonds like the track is jammed or broke on the one side.
Can you get it shut at all or is it stuck open?
IF the track is jammed or broke the motor may have blown a fuse. Typically these are all one unit, not serviced separatley. I'll see if I can verify that.
Sep 8, 2008 at 12:34 PM
PAUL.HANKINS
  • 6 POSTS
The passenger side tries to close and actually moves an inch or so. The driver side doesnt move at all and when the passenger side starts moving, the motor reverses when the passenger side gets out of alignment wuth driver side, and it moves back to full open position at which point the motor shuts off.
If there are two motors it could be a fuse on the driver side motor (assuming separately fused), if a single motor then its probably somethng mechanical. Any ideas?
Sep 8, 2008 at 12:41 PM
SERVICE WRITER
  • 9,123 POSTS
You need to dissemsemble to find out what is happening. The good news is that the parts are available individually.
https://images.2carpros.com/forum/automotive_pictures/30961_slide_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_slide1_1.jpg
Maybe it is just a matter of resetting it into the tracks...
Sep 8, 2008 at 12:46 PM
SERVICE WRITER
  • 9,123 POSTS
I think it is a mechanical binding on the driver's side. Maybe the cable is disconnected or the track is no longer connected to the roof.. IF this procedure doesn't work, it may confirm that:
https://images.2carpros.com/forum/automotive_pictures/30961_slide2_1.jpg
IT looks like one motor.
Sep 8, 2008 at 12:53 PM
PAUL.HANKINS
  • 6 POSTS
Thanks. I got the manual close operation to function. It closed the roof to within an inch of being completely shut before it couldnt move it any further. It seems to not have enough power to get it all the way closed. I re-opened it and it did the same thing as before, opening all the way and then clicking. To close, I had to activate manual again since the auto function still just inched it forward and then reversed.
Sounds to me like the track is either broken or off track. I guess I'll have to pull it apart. Have you ever done that? Is it relatively easy?
Sep 8, 2008 at 1:17 PM
SERVICE WRITER
  • 9,123 POSTS
I haven't had the pleasure...but this should help:
https://images.2carpros.com/forum/automotive_pictures/30961_toyrep1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyrep2_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyrep3_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyrep4_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyrep5_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyfig12_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyfig13_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyfig14_1.jpg
https://images.2carpros.com/forum/automotive_pictures/30961_toyfig16_1.jpg
Sep 8, 2008 at 1:36 PM
PAUL.HANKINS
  • 6 POSTS
Thanks. Appreciate it!
Sep 8, 2008 at 1:53 PM
PAUL.HANKINS
  • 6 POSTS
Sounds tedious! I'll give it a shot as soon as have a couple hours to spare and will let you know how it goes. Cheers.
Sep 8, 2008 at 1:55 PM
PAUL.HANKINS
  • 6 POSTS
The problem fixed itself (at least for now). I ran the roof as far closed as it would go manually, then opened it. I did this three times and the third time, as it opened it made a loud popping sound. After that it closed automatically all the way and reopened automatically fully open, with no unusual sounds. I presume it must have somehow 're-tracked' itself.
So, all is well. And good thing, we have flash flood warnings out all day as the rain moves in.
Thanks for the help.
Sep 9, 2008 at 12:44 AM
SERVICE WRITER
  • 9,123 POSTS
I fixed it over the internet...talented huh? LOL....Glad to hear your back in business.
Sep 9, 2008 at 10:44 AM
4RUNNER_BROKEN
I just had the same issue happen to my 2003 4Runner. The service manager at the Toyota Dealership told me that the cable came loose and got jammed in the sun roof housing. So the known cable issue caused all three parts to become damaged and need to be replaced. Well it's a good thing I bought the extended warranty to cover this. Well not exactly. They will only cover the motor $350with the warranty and want me to pay for the cable $500 and the housing $600 plus the labor $800 and in total $2300 to fix a sun roof that won't close. I've escalated the issue and was told to wait 2-3 days to see if they'll cover the costs since I did buy a warranty. It's all BS. I do appreciate the info on this post I will have to resort to this if I can't resolve this with Toyota. Any recommendations?
Oct 21, 2008 at 10:20 AM
AWILLIAMS811
Hello, Sounds like this is a somewhat common problem with these sunroofs. I'm having exactly the same noises and operations as previously described. Did you ever have the cable and housing replaced? Did that fix the problem? I had downloaded the Toyota TSB on repairing the guides and taken that to the dealership to fix....that fix only lasted 6 days before the same operation happened again. Trying to troubleshoot it for them so I can save some green. Let me know what worked for ya'll. Thank you!
Jun 22, 2009 at 2:50 AM
