2003 Toyota 4Runner Fan
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
PATTIANDSCOOTER
I was driving and my a/c was working fine...no unusual sounds. I got home and about an hour later restarted my engine. The a/c won't work (fan). It will not work in the heat mode either. I checked the inside fuses and they are all ok. Does this sound like a fuse problem (engine area). The coolant lines are still cold and the belts appear to be all ok and working. Like I said, no strange noises like bearings going out, etc. The fan just quit blowing. I don't believe it would be a switch problem, because I never turned it off. Any ideas?
Oct 11, 2010 at 6:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
could be fuse also check the blower motor relay
Oct 11, 2010 at 2:26 PM
