I was driving and my a/c was working fine...no unusual sounds. I got home and about an hour later restarted my engine. The a/c won't work (fan). It will not work in the heat mode either. I checked the inside fuses and they are all ok. Does this sound like a fuse problem (engine area). The coolant lines are still cold and the belts appear to be all ok and working. Like I said, no strange noises like bearings going out, etc. The fan just quit blowing. I don't believe it would be a switch problem, because I never turned it off. Any ideas?
Oct 11, 2010 at 1:51 PM
