2003 Toyota 4Runner a/c, heater fan
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
PATTIANDSCOOTER
A/C was working fine. No unusaul noises like bearings going or anything out of the ordinary. I stopped and turned the ignition off and about 30 minutes later restarted and the fan will not come on at all for either the A/C or heater. Inside fuses are ok. Do you think it could be the outside fuses? If not....any suggestions?
Oct 11, 2010 at 6:58 AM
  • 75,988 POSTS
Check all the heater fuses, blower motor relay and blower motor controller
Oct 11, 2010 at 10:10 AM
