2002 Toyota 4Runner engine
2002 TOYOTA 4RUNNER
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
WJBJ
the vehickle will start like normal and idle but when you press the accelrator the engine does not rev up.
Apr 8, 2009 at 9:30 AM
  • 31,937 POSTS
Hi there,
Make sure that the throttle is still connected to to accelerator pedal, and if so have the TPI sensor checked, start here.
Mark (mhpautos)
Apr 8, 2009 at 10:21 AM
WJBJ
[quote:fdcf52bd34="mhpautos"]Hi there,
Mark (mhpautos)[/quote:fdcf52bd34] throttle is connected. after vehicle set for an hour or so the engine started and ran fine. dont understand.
Apr 8, 2009 at 4:05 PM
  • 31,937 POSTS
Hi there,
I would run a scan and see if there were any fault codes set.
mark (mhpautos)
Apr 8, 2009 at 4:17 PM
