Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
4Runner
Engine
Symptoms
Idle High
2002 Toyota 4Runner engine
2002 TOYOTA 4RUNNER
117,000 MILES • 6 CYL • 2WD • AUTOMATIC
WJBJ
MEMBER
the vehickle will start like normal and idle but when you press the accelrator the engine does not rev up.
Apr 8, 2009 at 9:30 AM
Experienced Mechanic
Hi there,
Make sure that the throttle is still connected to to accelerator pedal, and if so have the TPI sensor checked, start here.
Mark (mhpautos)
Apr 8, 2009 at 10:21 AM
WJBJ
MEMBER
[quote:fdcf52bd34="mhpautos"]Hi there,
Mark (mhpautos)[/quote:fdcf52bd34] throttle is connected. after vehicle set for an hour or so the engine started and ran fine. dont understand.
Apr 8, 2009 at 4:05 PM
Hi there,
I would run a scan and see if there were any fault codes set.
mark (mhpautos)
Apr 8, 2009 at 4:17 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
