2001 Toyota 4Runner could it be bad gas...or the cadylic co
2001 TOYOTA 4RUNNER
120,987 MILES • 6 CYL • 4WD • AUTOMATIC
SABMARHAN
everytime i try to accelerate, my car jerks...i have to push the gas to the floor in order for it to go...it get a little past 20mph and goes back down to 10mph even with me still having my foot on the gas....then when i got out of the car the floor on the the passenger side of my truck was hot.
Apr 1, 2010 at 3:44 PM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 1, 2010 at 11:10 PM
