2001 Toyota 4Runner
143,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSHM722
The 4Runner started to miss and run poorly so I changed the plugs which I have done on 2 previous occations, but when I tried to start it it would act like it wanted to but never would. I checked the coils and and connectors, the front coil has no voltage from the connector I rotated the coils out just to make sure it wasnt the coil and even bought 3 new coils just to make sure it wasnt a problem with the old coils but there is still no power to the connector. I used a Multi Meter to check the ground and it is fine. I checked the wires going to the connector for cuts or nicks but everything looks good and is still in the factory wiring protector but I still have no voltage. Is there a sensor that would cause the voltage to appear on the other 2 coils but not the front coil or is there something I forgot to check.
Jan 22, 2008 at 10:09 AM
FISHERMAN
  • 937 POSTS
[quote:c15d502bc8="joshm722"]Electrical problem
2001 Toyota 4Runner 6 cyl Two Wheel Drive Automatic 143000 miles
The 4Runner started to miss and run poorly so I changed the plugs which I have done on 2 previous occations, but when I tried to start it it would act like it wanted to but never would. I checked the coils and and connectors, the front coil has no voltage from the connector I rotated the coils out just to make sure it wasnt the coil and even bought 3 new coils just to make sure it wasnt a problem with the old coils but there is still no power to the connector. I used a Multi Meter to check the ground and it is fine. I checked the wires going to the connector for cuts or nicks but everything looks good and is still in the factory wiring protector but I still have no voltage. Is there a sensor that would cause the voltage to appear on the other 2 coils but not the front coil or is there something I forgot to check.[/quote:c15d502bc8]
Hello Josh !!
Which cylinder number (coil pack) its the one its missing?
let me know..
Jan 22, 2008 at 10:25 AM
JOSHM722
[quote:be4951930d="fisherman"][quote:be4951930d="joshm722"]Electrical problem
The 4Runner started to miss and run poorly so I changed the plugs which I have done on 2 previous occations, but when I tried to start it it would act like it wanted to but never would. I checked the coils and and connectors, the front coil has no voltage from the connector I rotated the coils out just to make sure it wasnt the coil and even bought 3 new coils just to make sure it wasnt a problem with the old coils but there is still no power to the connector. I used a Multi Meter to check the ground and it is fine. I checked the wires going to the connector for cuts or nicks but everything looks good and is still in the factory wiring protector but I still have no voltage. Is there a sensor that would cause the voltage to appear on the other 2 coils but not the front coil or is there something I forgot to check.[/quote:be4951930d]
Hello Josh !!
let me know..[/quote:be4951930d]
Thanks for getting back to me. I am not sure how the cylinders are numbered on a toyota but the coil pack controls the front cylinder on the passenger side and the middle cylinder on the driver side. I hope this helps.
Jan 26, 2008 at 4:51 PM
