2000 Toyota 4Runner Washer Fluid Pump
88,000 MILES • 6 CYL • 4WD • AUTOMATIC
REESEMC2001
The washer fluid will not come out. I'm pretty sure it's not a leak in the hose because I don't even hear the pump trying to work. Also there is no fluid on the ground or any wet spots under the hood. I looked at the fuse box and pulled the "wiper" fuse. It's in tact and the wipers do indeed work. Is there a fuse that may be bad, if so how do I identify it? Is it that the pump has just gone bad? Is it easy to repair myself? Thanks
Aug 6, 2008 at 2:55 AM
KHLOW2008
  • 41,812 POSTS
Hi reesemc2001,
Wiper and washer motor uses the same fuse so you can rule out fuse,
Unplug the washer motor wire socket and test for power supply when washer switch is activated. Apply battery power to motor to test it.
Aug 17, 2008 at 1:49 AM
