2000 Toyota 4Runner Rusted bolts on O2 sensor
2000 TOYOTA 4RUNNER
77,000 MILES • 6 CYL • 4WD • AUTOMATIC
AMLEECO
Bolts are very badly rusted to the point that the studs may be damaged. My guy doesn't know if he can heat it up and remove the old 02 sesonr.
I really don't want to spend 1400 bucks on a new pipe.
Sep 8, 2010 at 9:48 AM
KHLOW2008
  • 41,814 POSTS
Hi amleeco,
Heat it up and spray some rust remover onto the areas surround the threads and pray that it works.
Even if the thread were damaged, it might not be necessary to replace the complete pipe. The threads can be repaired by a machinist, which should cost a lot lesser than $1400.
Sep 18, 2010 at 4:37 AM
