2000 Toyota 4Runner rear left power window problem
DIYLOVER
Electrical problem
2000 Toyota 4Runner 6 cyl Two Wheel Drive Automatic
Hi:
the driver rear side power window on my 2000 toyota 4runner is not working properly. it goes up and down, but really slow and it makes some kind of a dragging noise. Don't know if I have to replace the window motor or the window regulator rails.
any advise will be apprecciated.
thanks.
Jul 7, 2008 at 1:11 PM
KHLOW2008
  • 41,812 POSTS
Hi diylover,
It could be the motor, regulator or the glass run channels.
Spray some water onto the runchannels and if the glass moves well, replace it.
Otherwise you need to remove the door panel to have a look at the motor and regulators.
Jul 8, 2008 at 7:53 AM
